LaserPecker LP5 Add-ons: Enclosure & Air Purifier Tested Weโve just updated our LP5 review with two brand-new accessories: a safety enclosure and a modular air purifier. These upgrades make the powerful LP5 even more user-friendly and safer for indoor use. ๐ See the full update and test results here Let us know if you're using similar accessories or considering them for your setup!
Zachary 3D Prints joined the community
Creality ShareFest UK Birmingham 2025
Just published my write-up from the first Creality ShareFest event in the UK โ held in Birmingham this May. Lots of new machines, prize giveaways, and a great atmosphere with fellow 3D printing enthusiasts. ๐ Read the full article here Did you ever attend too? Or planning to join one in your country? Letโs discuss!
Bambu Lab P1S Gets an Upgrade โ Guide Coming Soon!
A big thank you to BigTreeTech and BIQU for sending over the full P1S upgrade kit, including the touchscreen and several flexible print beds to test. Looking forward to modifying my P1S and adding the ability to control my A1 from the same touchscreen! ๐ ๏ธ A full guide will be coming soon on 3DWithUs โ stay tuned! In the meantime, feel free to ask questions here ๐
๐ Update โ Full Review Now Live! The full hands-on review of the SUNLU FilaDryer SP2 is now published on our main site: ๐ Read the full article here Image: SUNLU FilaDryer E2 and SP2 in Comparison We go into detail about performance, modular design, noise levels, etc. Here is a short video with SP2 in Action, Including Thermal Camera View. Feel free to continue the discussion here - share your own experiences, ask questions, or post photos of your setup!
The Creality K1 Series CFS Upgrade Combo Kit just arrived for review! Iโm excited to share how this upgrade works with my K1 Max. A full review will be coming soon on 3DWithUs and the 3DPUK Tech YouTube channel. Got it already? Share your thoughts.
Weโve just published our hands-on review of the Flashforge AD5X, covering multi-color TPU performance, speed tests, and setup tips: ๐ Read the full review here Have you tested the AD5X with or without the IFS system? Share your experiences, tips, and print results! Quick look at the Flashforge AD5X 3D printer in action: Have you tested the AD5X with or without the IFS system? Share your experiences, tips, and print results!
Hi Charles, I havenโt personally tried it, but it should be possible by using adapters. For example, hereโs an adapter for cardboard spools I found on Thingiverse: https://www.thingiverse.com/thing:6888138 Here are the other examples: https://www.printables.com/model/472937-bambu-ams-spool-adapter-for-sunlu-195mm-spools This fix could also be helpful: https://www.printables.com/model/1103497-creality-k2-plus-cfs-fix-for-small-spools-retracti I recommend starting with the officially supported spool sizes for your first prints, just to get a good feel for how the system works. Also, I wouldn't start long projects until I am 100% sure the adapters work well.
Bonsoir je vien de passer comande de cette imprimante pour complรฉter ma collection de machine. J'aimerais savoir si on peu utilisรฉ des bobine de filament en 250 g ou 500 g dans lโunitรฉ CFS et si oui quel actuce ou chose a imprimer pour cela .
I just wrapped up testing the LaserPecker LP5, a portable dual-laser combination with an integrated 20W diode laser and 20W fiber laser. ๐งช In the full article, we go over material tests, tips, and cutting results: ๐ Read the review Got one yourself or curious about this model? Post your results, setups, or questions below or start a new thread!
Printed the first two parts in Inslogic3D PA6-CF - came out great on the Creality K2 Plus. Hardened steel tip nozzle handled it well. Now I just hope I donโt get disqualified for the filament choice! Mainframe and framecover parts for DeathRacerโฆ
Unboxing, setup, and first prints with the new Anycubic Kobra S1 Combo. From multi-material masks to practical test prints. Featured: Pipe Cox's Masks Have you tried this machine or plan to? Share your own prints, setup experience, or ask a question below! ๐ Full review: https://3dwithus.com/anycubic-kobra-s1-combo-review-3d-printer-tests-tips-and-settings
Has anyone here tried the Hoopat Quick Release Resin Vat from Chitu Systems? I requested one to test it out specifically on the Elegoo Saturn 2, and it has arrived! The unboxing was OK - I love the build quality at first glance. Curious to see how it performs in terms of cleanup and quick swaps. Let me know if youโve already tested it, or if you have any questions before I run it through some prints. The full article is coming soon. Here is the link to the product.
The eufyMake E1 is here! This machine blends UV color printing with 3D texturing, carving out a category of its own. For now, weโll keep it under the 3D Printing umbrella, but it definitely pushes the boundaries. Check out our full article here: https://3dwithus.com/eufymake-e1-3d-textured-uv-printer Share your thoughts and makes - if there's enough interest, we'll launch a new subforum to cover this emerging technology.
Working on a 3D design, model, or digital project? Whether you're creating for 3D printing, CNC, laser engraving, or just exploring new software - this is your space! โ Show your work-in-progress or finished designs โ Ask design-related questions โ Share tips for CAD, sculpting, slicing, or modeling โ STL sharing allowed (please credit designers where needed) ๐ฌ Popular tools include Fusion 360, Blender, TinkerCAD, LightBurn, FreeCAD, ZBrush, and more - but anything creative is welcome. ๐ Cross-technology projects (for printing, cutting, scanning, etc.) are encouraged too!
Exciting delivery today! The SUNLU FilaDryer SP2 just arrived, but the unboxing has been temporarily delayed... our in-house "border control officer" insists on a thorough inspection first. ๐ถ๐ฆ๐พ Looking forward to sharing more soon once we get it set up and tested! Stay tuned for first impressions and drying tests.
Laser Engraving on Stone-like Materials โ Share Your Results!
Engraving on stone-like materials, such as slate, ceramics, and tile, can produce stunning results for gifts, signs, or decorative items. We recently explored the process and materials in more detail here: ๐ How to Engrave on Stone, Ceramics, and Slate โ 3DWithUs Guide Different laser types, power settings, and surface prep all make a difference. ๐ฌ Tried it yourself? Show us your work! Post your results, materials, or questions below. ๐ธ Diode, COโ, or fiber โ all laser types welcome!
Campaign Announcements โ Share Yours Here
Do you have a live or upcoming campaign you'd like the community to be aware of? Whether it's on Kickstarter, Indiegogo, or another platform, if it's related to making, building, or digital fabrication, you're welcome to post. โ Hardware and software welcome โ Campaigns for designs (STLs, models, digital assets) are welcome โ Crowdfunding, pre-orders, and early access โ No Affiliate Links โ No spammy or unrelated promotions ๐ We recommend one thread per campaign for easier updates and questions.
Nice machine - Iโve had a chance to print on it as well. Here are a few models I printed on the FLSUN T1 Pro as part of my testing for the Einstar VEGA 3D scanner review: EISNTAR Mascot and 3D scanned and printed in SUNLU Blue PLA version. Fast and impressive results!
Just got hands-on with the FLSUN T1 Pro โ and wow, this Delta printer is a speed demon! From unboxing to setup and testing, the T1 Pro handled everything with surprising ease and accuracy. In the video, I walk through the initial setup and share a few first prints โ complete with STL sources. I also take a closer look at the machineโs design and usability, highlighting some of its most interesting features. Toward the end, I wrap up with the key specs and a few of my personal takeaways now that itโs had a proper test drive. I found it to be a fast and capable Delta-style 3D printer. Itโs designed to reach speeds of up to 1,000 mm/s and handle a range of materials, including PLA, PETG, TPU, ABS, ASA, and others. The printer features a direct drive extruder with a 300ยฐC brass nozzle, along with real-time monitoring and built-in time-lapse capture. ๐ฌ Have a T1 Pro or thinking of getting one? Drop your experience, questions, or print pics in this thread!
After seeing all the fun DeathRacer competitions organized by @TheRealSamPrentice at RepRap festivals, I couldnโt hold back any longer โ I had to get a kit myself! From BIQU Shop. This thread will follow my first impressions, build process, and testing, and who knows โ maybe even participation at an upcoming event like SMRRF! ๐ค DeathRacers, Pilots and Spectators at SMRRF2023 Stay tuned for: ๐ฆ Kit unboxing ๐ ๏ธ Assembly experience ๐ฎ Test runs & tuning ๐ Event-ready (or not ๐ ) Feel free to drop your own tips, questions, or DeathRacer setups below ๐
Thatโs a lot of engineering-grade filament to test. With the Creality K2 Plus, Snapmaker Artisan, and SUNLU E2, I think Iโm well equipped. ๐จโ๐ญ Itโs Engineering-grade filament: PA6-CF, PA12-CF, PC-ABS (white), Nylon PA6/66. I also have their popular materials such as TPU (black), PLA (matte Black), PETG (white), and ASA (black). If you'd like me to test anything specific, please let me know here in this thread. Check the availability of their filament on their official website.
๐ฃ Got Easter-themed 3D prints? Share your decorations, gifts, or functional models โ whether you designed it, printed it, or just have a cool remix! Featured: Bugman140, 3DPrintBunny, KOZA-Designs, 3DWithUs ๐ธ Post your photos, tell us what filament you used, and drop a link to the model (if it's public). โ STL sources (Printables, MyMiniFactory, Cults, etc.) welcome โ Designed by you or others โ just credit the designer โ Cross-technology prints/projects are welcome โ No AI renders or unprinted designs ๐ฐ Letโs keep this growing โ weโll feature some of your entries in our Easter 3D Print Ideas post and social media roundups.
We love seeing what our members are building! Youโre welcome to share personal projects, blogs, or shops โ but please keep it relevant and add context. โ Links to your own 3D prints, designs, or tutorials are encouraged when accompanied by insight, context, or helpful tips. โ Showcasing your tools, setups, or maker projects? Please do! ๐ก If youโre sharing a video, provide a brief summary so others know what to expect. ๐ซ Please avoid posting just a link without context โ itโs more helpful when we know what itโs about and why it matters. ๐ซ No spam, AI-generated posts, or โvisit my forum/siteโ link drops. ๐ซ Affiliate links are not allowed.
