I spent three weeks testing the 3DMakerpro Toucan. As usual, scanning for 3D printing was on my mind, but not limited to it. Here are a few pointers 👇 Takeaways: • Single Shot (similar to photogrammetry) mode is useful • Not needing a PC for scanning changes how and where you use it • Editing/alignment in JMStudio gives more control Full hands-on write-up (4+ examples) here: https://3dwithus.com/3dmakerpro-toucan-review-standalone-3d-scanning-example
Hi Farquit, if the fan does not spin at any setting or during use, that’s unfortunately not normal behaviour for a brand-new unit. In this case, I’d strongly recommend contacting 3DMakerpro support directly and explaining that the fan was noisy from the first power-on and now doesn’t spin at all, even after the update. That’s usually treated as a hardware issue rather than something the user can fix. Their contact details shown on the 3DMakerpro site footer are [email protected] (support) and [email protected], and the website is 3dmakerpro.com. On my side, I tested Toucan for more than 3 weeks and got plenty of results. I increased/decreased the fan flow via Settings> Fan, and it appeared my device didn't have difference in the noice.
