Great project! Good luck in the Balancing Games contest. I printed the dice so far. It came out nicely. Itโs a shame it takes so many color changes for the multicolor version (four colors). It took me 120 color changes and over seven hours to print, with a lot of purging. Hopefully, the next generation of tool- or nozzle-changing printers will make printing multicolored dice more feasible. I can imagine that in this game, if you print many more objects, there could be two dice โ one for the shape and another for the color code.
Weโve just published a new guide on 3DWithUs covering EINSTAR Rockit and EINSTAR 2, SHINING 3Dโs latest additions to the EINSTAR lineup. Both scanners focus on wireless workflows and accessible 3D scanning, with slightly different positioning and pricing. https://3dwithus.com/shining3d-einstar-new-3d-scanners Weโre opening this thread to hear real-world experiences from the community. If youโre using Rockit or EINSTAR 2, feel free to share what youโre scanning, how it performs for you, or any tips worth passing on. If youโre still deciding, questions are welcome too. Looking forward to your input and discussions.
A Small Moment ๐ Behind the Scenes
Just sharing a nice behind-the-scenes moment from the resin 3D printing world. Small surprises like this are quite common in the 3D printing community. A thoughtful gift and a note from Piocreate and CHITUBOX arrived recently! Teddy inspected the delivery and gave it his full approval ๐ถ At this point, I should probably start asking for gifts for Teddy โ he goes through everything like a tank. ๐ถ๐ Got a similar surprise? Feel free to share it here on the forum โ always nice to see these small moments.
๐ December Giveaway Completed โ January Giveaway Is On The Way! Huge thanks to our early forum supporters! We're excited to award our filament prize to forum contributors ๐ ๐ Winning contributions: Upgrade for Prusa Mini: https://3dwithus.com/forum/topic/985-installation-video-for-upgrade-kit-for-prusa-mini-and-promo-code Automated 3D Scanning: https://3dwithus.com/forum/topic/988-robotic-3d-scanning-for-automation-anyone-tried-this 2* Two SUNLU filament spools are now on their way ๐ What's Nextโ The January giveaway is live โ 2 ร SUNLU filament spools will be awarded (Best Post or/and Best Comment) โ All helpful & creative contributions count Share your projects, tips, questions, fails & wins. Every contribution helps grow the community and puts you in the running. If you were considering posting but havenโt jumped in yet, this is the perfect time to start. Sign Up Here https://3dwithus.com/forum/register/
Robotic 3D scanning for automation โ anyone tried this?
Hi Emily, great topic. From my experience of testing various 3D scanners, I can say that scanning can become very time-consuming. Manual scanning works, but testing the same part across different scanning modes takes even longer. Then again, more angles and rescanning may be required - so yes, automation of this process could be very welcome. A robotic arm can be genuinely helpful in those cases. I saw a robotic arm 3D scanning setup from Revopoint at Formnext, and it was impressive in terms of automation. I donโt see it as essential for everyone, but for repeat scans, inspection, or small-batch workflows, it can be a real efficiency boost. Revopoint Robotic Arm 3D Scanning at Formnext
Congratulations! ๐ This post won two filament spools in the Contribute to Win - December 2025 giveaway. We will contact you shortly to arrange the delivery of two SUNLU filament spools. Giveaway Rules: https://3dwithus.com/forum/topic/973-contribute-to-win-monthly-giveaway
Hi Farquit, if the fan does not spin at any setting or during use, thatโs unfortunately not normal behaviour for a brand-new unit. In this case, Iโd strongly recommend contacting 3DMakerpro support directly and explaining that the fan was noisy from the first power-on and now doesnโt spin at all, even after the update. Thatโs usually treated as a hardware issue rather than something the user can fix. Their contact details shown on the 3DMakerpro site footer are [email protected] (support) and [email protected], and the website is 3dmakerpro.com. On my side, Iโll be testing a Toucan unit that was sent to me next week, and Iโll update this thread with how it performs during real-world use, including noise and cooling behaviour.
Hi all, Iโve been looking into automated 3D scanning with robots for repetitive scanning tasks. Manual scanning works, but consistency can be an issue when doing the same part again and again. Recently I came across a robotic scanning setup called MetroHub, which combines a 3D scanner with a robotic arm. Iโm curious if anyone here has experience with robot-assisted 3D scanning or similar systems. Is it mainly about consistency, or does it really improve overall efficiency in real use? Just trying to understand whether robotic scanning is practical outside large factories. Would love to hear your thoughts.
Just showing off. I had a great experience printing engineering-grade materials on my Creality K2 Plus and now on the K2 Pro. PC-ABS can be stubborn to stay on the bed, and warping is a real issue. A heated print bed, heated chamber, and high-temperature extruder make it possible. In the image, the K2 Pro is printing modified Joel Telling shelf brackets. Now we have a nice shelf for Teddyโs ๐ถ clothes and licking mat collection. Here are more test print results. Did you have experience with this machine, or do you have any questions? Post here.
The festive season is here, and this thread is a place to share Christmas-themed 3D print ideas, projects, and finished prints. ๐ Christmas 3D Print Ideas Guide: https://3dwithus.com/christmas-3d-print-ideas The festive season is here โ time to fire up your 3D printer ๐ Please, share your ideas and prints! If you share a project, please start a new thread.
Hi everyone, If you're interested in upgrade kit for Prusa Mini+, you can view the Full installation video here: ๐ฆ Notes about the kitYouโll need an existing Prusa Mini or Mini+. Some printed plastic parts are required (G-code is provided, or you can order printed parts separately). Shipping is handled via Amazon FBA, and it comes with free returns, which is reassuring for a DIY upgrade. ๐ Discount for forum membersIf youโre interested in this upgrade, hereโs a 40% off promo code: Promo Code: 9DQEI7MN Product Link: https://www.amazon.com/dp/B0FM76L72M Feel free to share your thoughts or ask questions below!
The 3DMakerPro Toucan has arrived. The box was received and inspected by our very strict quality control officer, Teddy ๐ถ Unboxing, and the first scans will be coming soon. Have you tried this scanner? Share your experience with us.
Weโve just published a guide to the 3D Printing Industry Awards and how they work, including the people and processes behind them. https://3dwithus.com/inside-the-3dpi-awards Do you follow the 3DPI Awards each year? Do you think they reflect whatโs happening in the industry? Who or what do you see as most influential right now? Feel free to share your thoughts and experiences.
Quick Update: The full hands-on article is now live! I tested the PollyFab Flux and Aero shoes over several weeks, including a full stress test at Formnext, cross-trainer sessions, outdoor walking, and various sock/barefoot combinations. Plenty of photos, impressions, and practical notes inside. ๐ Read the full review: https://3dwithus.com/pollyfab-3d-printed-shoes-comfort-design-and-durability-test A little bit of visuals: Feel free to share your own experience if youโve tried any fully 3D printed lattice shoes, or ask anything I didnโt cover in the article. Happy to test more scenarios!
Update: Revopoint INSPIRE 2 Hands-On Iโve just published my hands-on article with the Revopoint INSPIRE 2, covering setup, mobile mode, marker scanning, merging, color tests, and even a 3D print based on the scan. ๐ Full write-up: https://3dwithus.com/revopoint-inspire-2-hands-on-lightweight-3d-scanner My Christmas Tree ๐ will have a special decoration this year. It will also work as a reminder and a new year's resolution to continue certain projects ๐ค๐ Feel free to ask if you want any specific test, comparison, or scan example.
๐ November Giveaway Completed โ December Giveaway Is On The Way! Huge thanks to our early forum supporters! We're excited to award our first filament prize to an early contributor ๐ ๐ Winning contribution: https://3dwithus.com/forum/topic/981-kad3d-australias-most-recommended-3d-printing-and-manufacturing-service Two SUNLU filament spools are now on their way ๐ What's Nextโ December giveaway is live โ 2 ร SUNLU filament spools will be awarded (Best Post or/and Best Comment) โ All helpful & creative contributions count Share your projects, tips, questions, fails & wins. Every contribution helps grow the community and puts you in the running. If you were considering posting but havenโt jumped in yet, this is the perfect time to start. Sign Up Here https://3dwithus.com/forum/register/
