Hi Farquit, if the fan does not spin at any setting or during use, that’s unfortunately not normal behaviour for a brand-new unit. In this case, I’d strongly recommend contacting 3DMakerpro support directly and explaining that the fan was noisy from the first power-on and now doesn’t spin at all, even after the update. That’s usually treated as a hardware issue rather than something the user can fix. Their contact details shown on the 3DMakerpro site footer are [email protected] (support) and [email protected], and the website is 3dmakerpro.com. On my side, I’ll be testing a Toucan unit that was sent to me next week, and I’ll update this thread with how it performs during real-world use, including noise and cooling behaviour.
Farquit joined the community
Jangidlalit joined the community
🎉 November Giveaway Completed — December Giveaway Is On The Way! Huge thanks to our early forum supporters! We're excited to award our first filament prize to an early contributor 🙌 🏆 Winning contribution: https://3dwithus.com/forum/topic/981-kad3d-australias-most-recommended-3d-printing-and-manufacturing-service Two SUNLU filament spools are now on their way 🎁 What's Next✅ December giveaway is live ✅ 2 × SUNLU filament spools will be awarded (Best Post or/and Best Comment) ✅ All helpful & creative contributions count Share your projects, tips, questions, fails & wins. Every contribution helps grow the community and puts you in the running. If you were considering posting but haven’t jumped in yet, this is the perfect time to start. Sign Up Here https://3dwithus.com/forum/register/
KAD3D — Australia’s Most Recommended 3D Printing and Manufacturing Service
Congratulations! 🎉 This post has been selected as the Best Post of November 2025. We will contact you shortly to arrange the delivery of two SUNLU filament spools. Giveaway Rules: https://3dwithus.com/forum/topic/973-contribute-to-win-monthly-giveaway
Uniformation GK3 Pro Discussion
Uniformation GK3 Pro Hands-On: 16K Detail, Auto Resin Feed, Test Prints 🔎 Premium Resin 3D Printer – Assembly, Prints & Thoughts ✍ https://3dwithus.com/uniformation-gk3-pro-hands-on-review 📹 https://youtu.be/UGOV6v9NYJw Featured designs: @3dUniformation, @stlflix, Nostalgic3DModels #uniformation #resin3dprinter #3dprinting Have you tried this 3D printer? Let us know your experience, or feel free to ask anything about setup and usage!
Formnext Yearly Highlights
A quick look at what caught my eye this year (2025): the toolchanger showdown in Hall 12.1, stress-testing 3D printed shoes, the CubeMe generator, new compact lasers and scanners, and plenty of innovation on the consumer and small-business side of 3D printing. https://3dwithus.com/formnext-3d-printing-industry-event-highlights-preview#Formnext%202025
