Hi Farquit, if the fan does not spin at any setting or during use, that’s unfortunately not normal behaviour for a brand-new unit. In this case, I’d strongly recommend contacting 3DMakerpro support directly and explaining that the fan was noisy from the first power-on and now doesn’t spin at all, even after the update. That’s usually treated as a hardware issue rather than something the user can fix. Their contact details shown on the 3DMakerpro site footer are [email protected] (support) and [email protected], and the website is 3dmakerpro.com. On my side, I’ll be testing a Toucan unit that was sent to me next week, and I’ll update this thread with how it performs during real-world use, including noise and cooling behaviour.
Farquit joined the community
Jangidlalit joined the community
🎉 November Giveaway Completed — December Giveaway Is On The Way! Huge thanks to our early forum supporters! We're excited to award our first filament prize to an early contributor 🙌 🏆 Winning contribution: https://3dwithus.com/forum/topic/981-kad3d-australias-most-recommended-3d-printing-and-manufacturing-service Two SUNLU filament spools are now on their way 🎁 What's Next✅ December giveaway is live ✅ 2 × SUNLU filament spools will be awarded (Best Post or/and Best Comment) ✅ All helpful & creative contributions count Share your projects, tips, questions, fails & wins. Every contribution helps grow the community and puts you in the running. If you were considering posting but haven’t jumped in yet, this is the perfect time to start. Sign Up Here https://3dwithus.com/forum/register/
KAD3D — Australia’s Most Recommended 3D Printing and Manufacturing Service
Congratulations! 🎉 This post has been selected as the Best Post of November 2025. We will contact you shortly to arrange the delivery of two SUNLU filament spools. Giveaway Rules: https://3dwithus.com/forum/topic/973-contribute-to-win-monthly-giveaway
