🚀 Update – Full Review Now Live! The full hands-on review of the SUNLU FilaDryer SP2 is now published on our main site: 👉 Read the full article here Image: SUNLU FilaDryer E2 and SP2 in Comparison We go into detail about performance, modular design, noise levels, etc. Here is a short video with SP2 in Action, Including Thermal Camera View. Feel free to continue the discussion here - share your own experiences, ask questions, or post photos of your setup!
The Creality K1 Series CFS Upgrade Combo Kit just arrived for review! I’m excited to share how this upgrade works with my K1 Max. A full review will be coming soon on 3DWithUs and the 3DPUK Tech YouTube channel. Got it already? Share your thoughts.
We’ve just published our hands-on review of the Flashforge AD5X, covering multi-color TPU performance, speed tests, and setup tips: 🔗 Read the full review here Have you tested the AD5X with or without the IFS system? Share your experiences, tips, and print results! Quick look at the Flashforge AD5X 3D printer in action: Have you tested the AD5X with or without the IFS system? Share your experiences, tips, and print results!
SMRRF Yearly Highlights
