The Creality K1 Series CFS Upgrade Combo Kit just arrived for review! I’m excited to share how this upgrade works with my K1 Max. A full review will be coming soon on 3DWithUs and the 3DPUK Tech YouTube channel. Got it already? Share your thoughts.
We’ve just published our hands-on review of the Flashforge AD5X, covering multi-color TPU performance, speed tests, and setup tips: 🔗 Read the full review here Have you tested the AD5X with or without the IFS system? Share your experiences, tips, and print results! Quick look at the Flashforge AD5X 3D printer in action: Have you tested the AD5X with or without the IFS system? Share your experiences, tips, and print results!
SUNLU FilaDryer SP2 Just Arrived
SMRRF Yearly Highlights
We have been visiting SMRRF for a few years now, and have kept a single evolving article updated with highlights from each show. From exciting product launches to standout displays, it's been a go-to for yearly 3D printing event coverage. 🔗 Full article with links, photos, and past coverage: 👉 SMRRF Yearly Highlights DeathRacers, Pilots and Spectators at SMRRF2023 💬 Have your own SMRRF experience to share? Whether you’re attending this year, exhibiting, or just following online, we’d love to hear from you! 👉 Comment here or start a new thread in the SMRRF Forum to share your insights, photos, or impressions.
