  1. Last week
  2. AlanHudson joined the community
  3. Love it! Here is printed MediumHexagon_WithHandle I added color to it (four colors total). To my delight, it took me only a little over two hours to print on my Creality K2 Pro, with just a few color changes. I forgot to paint the base; it would have been a rainbow umbrella then. I was surprised at how many positions I could take with it. It was enlightening.
  4. Thanks! The die wasn't meant to be printed in multicolor :D, I printed it out in 1 color and then colored the shapes in with a sharpie. But yours came out great!
  5. Great project! Good luck in the Balancing Games contest. I printed the dice so far. It came out nicely. It’s a shame it takes so many color changes for the multicolor version (four colors). It took me 120 color changes and over seven hours to print, with a lot of purging. Hopefully, the next generation of tool- or nozzle-changing printers will make printing multicolored dice more feasible. I can imagine that in this game, if you print many more objects, there could be two dice — one for the shape and another for the color code.
  6. Earlier
  7. Hi! I would like to showcase another project of mine: A Balance Tetris Game! How to play?Take turns by placing blocks on the base by either rolling the die for it or choosing a preferred block. If the tower collapses on your turn, you lose! Printing tips:Different wall count and infill % have great impact on the game. I used 2 walls and 15% for every piece. You can print the base with 0 infill, 0 top/bottom layers. Scale it to your preferred size! 50% works just fine as well! I also recommend scaling the tetris die up to 133% (20mm). I recommend printing the solid blocks and the base on a holographic plate. It gives them a great look (Check out the last few pictures)! How to customize your own:To use the project files (.FCStd) you will need FreeCAD, a free to use/download CAD software. After opening the project you will see on the left side all the folders with the models and parameters. When you are done just export the models one by one: Select one of the models, then press Ctrl + e or Top menu > File > Export... The parameters:BaseArcOffset: Offsets the (circle's) arc on the base piece. BaseTeethCount: The number of teeth (slots) on the base piece. EdgeLength: The size of the blocks. GridWallWidth: The wall width of the Grid Blocks. (Solid blocks are not affected) DiceEmbossDepth: The depth of the emboss on the dice PedestalLength: The horizontal length of the pedestal. (The width is always 3 * EdgeLength) PedestalSlotDepth: The depth of the slot the base goes into. PedestalHeight: The height of the pedestal. The project is not foolproof, setting negative/incorrect parameter values might mess up the geometry completely! Happy printing and customizing!I hope you like it! The project is available here: https://www.printables.com/model/1549635-balance-tetris-customizable Other pictures:
  8. Hi everyone! I would like to share one of my recent projects with you: A Parametric Polygon Fidget It is fully customizable in FreeCAD and contains some premade ones as well if you don't feel like creating your own. The project is available here. So what can you customize?Number of sides for the polygon Segment/layer count of the fidget Wall width Wall angle Spacing Overall size: Height, Width Handle size (The handle is optional) (You can make insideout fidgets as well with it! See last 2 attached pictures!) Happy printing and customizing!The project is available on Printables: https://www.printables.com/model/1537410-polygon-fidgets-fully-customizable-trianglesquarep Showcase pictures:
  9. Marcidy joined the community
  10. My first object scanned with the 3DMakerpro Toucan was a clear success. I started with a travel mug featuring the Flashforge logo, which turned out to be a very scan-friendly object. The geometry and surface details were captured well, and within a short time, I was able to turn the scan into multiple variants, including a keychain, a miniature, and even a small Christmas ornament. For cleanup, I initially used JMStudio. JMStudio handled the scan processing and mesh cleanup smoothly, and it gave me a solid file that was already suitable for 3D printing with minimal extra work. To take it a step further, I moved into Blender. I wanted to add an extra design element to the model. While I could have recreated the Flashforge logo from the image, I was short on time, so I asked ChatGPT to generate a simple 2 mm-thick 'Recycle' feature from an image instead, which I could then embed directly into the model. This was an interesting discovery. ChatGPT provided me with the element I needed very quickly. Sliced and effortlessly color-printed on Creality K2 Pro.
  11. We’ve just published a new guide on 3DWithUs covering EINSTAR Rockit and EINSTAR 2, SHINING 3D’s latest additions to the EINSTAR lineup. Both scanners focus on wireless workflows and accessible 3D scanning, with slightly different positioning and pricing. https://3dwithus.com/shining3d-einstar-new-3d-scanners We’re opening this thread to hear real-world experiences from the community. If you’re using Rockit or EINSTAR 2, feel free to share what you’re scanning, how it performs for you, or any tips worth passing on. If you’re still deciding, questions are welcome too. Looking forward to your input and discussions.
  12. scottyp66 joined the community
  13. 3DVET joined the community
  14. Just sharing a nice behind-the-scenes moment from the resin 3D printing world. Small surprises like this are quite common in the 3D printing community. A thoughtful gift and a note from Piocreate and CHITUBOX arrived recently! Teddy inspected the delivery and gave it his full approval 🐶 At this point, I should probably start asking for gifts for Teddy — he goes through everything like a tank. 🐶😅 Got a similar surprise? Feel free to share it here on the forum — always nice to see these small moments.
  15. Abby joined the community
  16. 🎉 December Giveaway Completed — January Giveaway Is On The Way! Huge thanks to our early forum supporters! We're excited to award our filament prize to forum contributors 🙌 🏆 Winning contributions: Upgrade for Prusa Mini: https://3dwithus.com/forum/topic/985-installation-video-for-upgrade-kit-for-prusa-mini-and-promo-code Automated 3D Scanning: https://3dwithus.com/forum/topic/988-robotic-3d-scanning-for-automation-anyone-tried-this 2* Two SUNLU filament spools are now on their way 🎁 What's Next✅ The January giveaway is live ✅ 2 × SUNLU filament spools will be awarded (Best Post or/and Best Comment) ✅ All helpful & creative contributions count Share your projects, tips, questions, fails & wins. Every contribution helps grow the community and puts you in the running. If you were considering posting but haven’t jumped in yet, this is the perfect time to start. Sign Up Here https://3dwithus.com/forum/register/
  17. Hi Emily, great topic. From my experience of testing various 3D scanners, I can say that scanning can become very time-consuming. Manual scanning works, but testing the same part across different scanning modes takes even longer. Then again, more angles and rescanning may be required - so yes, automation of this process could be very welcome. A robotic arm can be genuinely helpful in those cases. I saw a robotic arm 3D scanning setup from Revopoint at Formnext, and it was impressive in terms of automation. I don’t see it as essential for everyone, but for repeat scans, inspection, or small-batch workflows, it can be a real efficiency boost. Revopoint Robotic Arm 3D Scanning at Formnext
  18. Congratulations! 🎉 This post won two filament spools in the Contribute to Win - December 2025 giveaway. We will contact you shortly to arrange the delivery of two SUNLU filament spools. Giveaway Rules: https://3dwithus.com/forum/topic/973-contribute-to-win-monthly-giveaway
  19. Congratulations! 🎉 This post won two filament spools in the Contribute to Win - December 2025 giveaway. We will contact you shortly to arrange the delivery of two SUNLU filament spools. Giveaway Rules: https://3dwithus.com/forum/topic/973-contribute-to-win-monthly-giveaway
  20. Hi Farquit, if the fan does not spin at any setting or during use, that’s unfortunately not normal behaviour for a brand-new unit. In this case, I’d strongly recommend contacting 3DMakerpro support directly and explaining that the fan was noisy from the first power-on and now doesn’t spin at all, even after the update. That’s usually treated as a hardware issue rather than something the user can fix. Their contact details shown on the 3DMakerpro site footer are [email protected] (support) and [email protected], and the website is 3dmakerpro.com. On my side, I’ll be testing a Toucan unit that was sent to me next week, and I’ll update this thread with how it performs during real-world use, including noise and cooling behaviour.
  21. Hi all, I’ve been looking into automated 3D scanning with robots for repetitive scanning tasks. Manual scanning works, but consistency can be an issue when doing the same part again and again. Recently I came across a robotic scanning setup called MetroHub, which combines a 3D scanner with a robotic arm. I’m curious if anyone here has experience with robot-assisted 3D scanning or similar systems. Is it mainly about consistency, or does it really improve overall efficiency in real use? Just trying to understand whether robotic scanning is practical outside large factories. Would love to hear your thoughts.
  22. Emily joined the community
  23. Scott joined the community
  24. Having an issue with my brand new Toucan. Had it on for about 15 minutes total. Fan seemed quite loud and 'grindy' from first turn on, grindy noise less noticeable at 100%. Not sure if it was the update @ 12/26/25 but since then the fan does not come on at all no matter what percentage it is set at. Not good. Any ideas?
  25. Farquit joined the community
  26. Just showing off. I had a great experience printing engineering-grade materials on my Creality K2 Plus and now on the K2 Pro. PC-ABS can be stubborn to stay on the bed, and warping is a real issue. A heated print bed, heated chamber, and high-temperature extruder make it possible. In the image, the K2 Pro is printing modified Joel Telling shelf brackets. Now we have a nice shelf for Teddy’s 🐶 clothes and licking mat collection. Here are more test print results. Did you have experience with this machine, or do you have any questions? Post here.
  27. Loved doing this guide for 3Dwithus.
  28. The festive season is here, and this thread is a place to share Christmas-themed 3D print ideas, projects, and finished prints. 👉 Christmas 3D Print Ideas Guide: https://3dwithus.com/christmas-3d-print-ideas The festive season is here — time to fire up your 3D printer 🎅 Please, share your ideas and prints! If you share a project, please start a new thread.
  29. Hi everyone, If you're interested in upgrade kit for Prusa Mini+, you can view the Full installation video here: 📦 Notes about the kitYou’ll need an existing Prusa Mini or Mini+. Some printed plastic parts are required (G-code is provided, or you can order printed parts separately). Shipping is handled via Amazon FBA, and it comes with free returns, which is reassuring for a DIY upgrade. 🎁 Discount for forum membersIf you’re interested in this upgrade, here’s a 40% off promo code: Promo Code: 9DQEI7MN Product Link: https://www.amazon.com/dp/B0FM76L72M Feel free to share your thoughts or ask questions below!
  30. The 3DMakerPro Toucan has arrived. The box was received and inspected by our very strict quality control officer, Teddy 🐶 Unboxing, and the first scans will be coming soon. Have you tried this scanner? Share your experience with us.
  31. We’ve just published a guide to the 3D Printing Industry Awards and how they work, including the people and processes behind them. https://3dwithus.com/inside-the-3dpi-awards Do you follow the 3DPI Awards each year? Do you think they reflect what’s happening in the industry? Who or what do you see as most influential right now? Feel free to share your thoughts and experiences.
  32. Quick Update: The full hands-on article is now live! I tested the PollyFab Flux and Aero shoes over several weeks, including a full stress test at Formnext, cross-trainer sessions, outdoor walking, and various sock/barefoot combinations. Plenty of photos, impressions, and practical notes inside. 👉 Read the full review: https://3dwithus.com/pollyfab-3d-printed-shoes-comfort-design-and-durability-test A little bit of visuals: Feel free to share your own experience if you’ve tried any fully 3D printed lattice shoes, or ask anything I didn’t cover in the article. Happy to test more scenarios!
  33. Update: Revopoint INSPIRE 2 Hands-On I’ve just published my hands-on article with the Revopoint INSPIRE 2, covering setup, mobile mode, marker scanning, merging, color tests, and even a 3D print based on the scan. 📄 Full write-up: https://3dwithus.com/revopoint-inspire-2-hands-on-lightweight-3d-scanner My Christmas Tree 🎄 will have a special decoration this year. It will also work as a reminder and a new year's resolution to continue certain projects 🚤😇 Feel free to ask if you want any specific test, comparison, or scan example.
  34. 🎉 November Giveaway Completed — December Giveaway Is On The Way! Huge thanks to our early forum supporters! We're excited to award our first filament prize to an early contributor 🙌 🏆 Winning contribution: https://3dwithus.com/forum/topic/981-kad3d-australias-most-recommended-3d-printing-and-manufacturing-service Two SUNLU filament spools are now on their way 🎁 What's Next✅ December giveaway is live ✅ 2 × SUNLU filament spools will be awarded (Best Post or/and Best Comment) ✅ All helpful & creative contributions count Share your projects, tips, questions, fails & wins. Every contribution helps grow the community and puts you in the running. If you were considering posting but haven’t jumped in yet, this is the perfect time to start. Sign Up Here https://3dwithus.com/forum/register/
  35. Congratulations! 🎉 This post has been selected as the Best Post of November 2025. We will contact you shortly to arrange the delivery of two SUNLU filament spools. Giveaway Rules: https://3dwithus.com/forum/topic/973-contribute-to-win-monthly-giveaway
