  1. Last week
  2. Hi Freeman, thanks for sharing your experience, and sorry to hear about the trouble! It sounds like there may be an issue with bed calibration or a possible firmware mismatch with CrealityPrint 6. By the way, CrealityPrint had a recent update to v6.1.1.2274 I would try the following: Update CrealityPrint, and the Firmware (on the printer). Re-run the full calibration and belt tension check from the touchscreen menu. If it still fails, try slicing a basic model in OrcaSlicer using Creality Hi profile for comparison. Let us know what works or if the issue persists - happy to help troubleshoot further.
  3. Hi Charles, I haven’t personally tried it, but it should be possible by using adapters. For example, here’s an adapter for cardboard spools I found on Thingiverse: https://www.thingiverse.com/thing:6888138 Here are the other examples: https://www.printables.com/model/472937-bambu-ams-spool-adapter-for-sunlu-195mm-spools This fix could also be helpful: https://www.printables.com/model/1103497-creality-k2-plus-cfs-fix-for-small-spools-retracti I recommend starting with the officially supported spool sizes for your first prints, just to get a good feel for how the system works. Also, I wouldn't start long projects until I am 100% sure the adapters work well.
  4. Freeman joined the community
  5. Hi. I received this printer yesterday and unfortunately only problems with it. At the start the self-test goes well, everything is green. Default projects uploaded by the manufacturer print correctly. However, all other projects cut in CrealityPrint 6.0 / 6.1 print incorrectly. The Y axis can suddenly move backwards or forwards and the nozzle works in the air, creating spaghetti and the print has to be thrown away. It even happened that the hotbed suddenly moved from its place, so much so that the belt jumped on the stepper motor gear and get axis y resistance error. I don't know how to solve this problem... Creality Community ForumError CM2789 helpI have Creality Hi, after starting it I started printing what was on the printer by default (waste container and speed test print) everything came out ok. Then from CrealityPrint6.1 I selected a te...
  6. charles joined the community
  7. Bonsoir je vien de passer comande de cette imprimante pour compléter ma collection de machine. J'aimerais savoir si on peu utilisé des bobine de filament en 250 g ou 500 g dans l’unité CFS et si oui quel actuce ou chose a imprimer pour cela .
  8. I just wrapped up testing the LaserPecker LP5, a portable dual-laser combination with an integrated 20W diode laser and 20W fiber laser. 🧪 In the full article, we go over material tests, tips, and cutting results: 👉 Read the review Got one yourself or curious about this model? Post your results, setups, or questions below or start a new thread!
  9. Printed the first two parts in Inslogic3D PA6-CF - came out great on the Creality K2 Plus. Hardened steel tip nozzle handled it well. Now I just hope I don’t get disqualified for the filament choice! Mainframe and framecover parts for DeathRacer…
  10. Earlier
  11. Unboxing, setup, and first prints with the new Anycubic Kobra S1 Combo. From multi-material masks to practical test prints. Featured: Pipe Cox's Masks Have you tried this machine or plan to? Share your own prints, setup experience, or ask a question below! 👉 Full review: https://3dwithus.com/anycubic-kobra-s1-combo-review-3d-printer-tests-tips-and-settings
  12. Has anyone here tried the Hoopat Quick Release Resin Vat from Chitu Systems? I requested one to test it out specifically on the Elegoo Saturn 2, and it has arrived! The unboxing was OK - I love the build quality at first glance. Curious to see how it performs in terms of cleanup and quick swaps. Let me know if you’ve already tested it, or if you have any questions before I run it through some prints. The full article is coming soon. Here is the link to the product.
  13. The eufyMake E1 is here! This machine blends UV color printing with 3D texturing, carving out a category of its own. For now, we’ll keep it under the 3D Printing umbrella, but it definitely pushes the boundaries. Check out our full article here: https://3dwithus.com/eufymake-e1-3d-textured-uv-printer Share your thoughts and makes - if there's enough interest, we'll launch a new subforum to cover this emerging technology.
  14. Working on a 3D design, model, or digital project? Whether you're creating for 3D printing, CNC, laser engraving, or just exploring new software - this is your space! ✅ Show your work-in-progress or finished designs ✅ Ask design-related questions ✅ Share tips for CAD, sculpting, slicing, or modeling ✅ STL sharing allowed (please credit designers where needed) 💬 Popular tools include Fusion 360, Blender, TinkerCAD, LightBurn, FreeCAD, ZBrush, and more - but anything creative is welcome. 👀 Cross-technology projects (for printing, cutting, scanning, etc.) are encouraged too!
  15. Exciting delivery today! The SUNLU FilaDryer SP2 just arrived, but the unboxing has been temporarily delayed... our in-house "border control officer" insists on a thorough inspection first. 🐶📦🐾 Looking forward to sharing more soon once we get it set up and tested! Stay tuned for first impressions and drying tests.
  16. Engraving on stone-like materials, such as slate, ceramics, and tile, can produce stunning results for gifts, signs, or decorative items. We recently explored the process and materials in more detail here: 👉 How to Engrave on Stone, Ceramics, and Slate – 3DWithUs Guide Different laser types, power settings, and surface prep all make a difference. 💬 Tried it yourself? Show us your work! Post your results, materials, or questions below. 📸 Diode, CO₂, or fiber — all laser types welcome!
  17. Do you have a live or upcoming campaign you'd like the community to be aware of? Whether it's on Kickstarter, Indiegogo, or another platform, if it's related to making, building, or digital fabrication, you're welcome to post. ✅ Hardware and software welcome ✅ Campaigns for designs (STLs, models, digital assets) are welcome ✅ Crowdfunding, pre-orders, and early access ❌ No Affiliate Links ❌ No spammy or unrelated promotions 📌 We recommend one thread per campaign for easier updates and questions.
  18. Nice machine - I’ve had a chance to print on it as well. Here are a few models I printed on the FLSUN T1 Pro as part of my testing for the Einstar VEGA 3D scanner review: EISNTAR Mascot and 3D scanned and printed in SUNLU Blue PLA version. Fast and impressive results!
  19. Just got hands-on with the FLSUN T1 Pro — and wow, this Delta printer is a speed demon! From unboxing to setup and testing, the T1 Pro handled everything with surprising ease and accuracy. In the video, I walk through the initial setup and share a few first prints — complete with STL sources. I also take a closer look at the machine’s design and usability, highlighting some of its most interesting features. Toward the end, I wrap up with the key specs and a few of my personal takeaways now that it’s had a proper test drive. I found it to be a fast and capable Delta-style 3D printer. It’s designed to reach speeds of up to 1,000 mm/s and handle a range of materials, including PLA, PETG, TPU, ABS, ASA, and others. The printer features a direct drive extruder with a 300°C brass nozzle, along with real-time monitoring and built-in time-lapse capture. 💬 Have a T1 Pro or thinking of getting one? Drop your experience, questions, or print pics in this thread!
  20. After seeing all the fun DeathRacer competitions organized by @TheRealSamPrentice at RepRap festivals, I couldn’t hold back any longer — I had to get a kit myself! From BIQU Shop. This thread will follow my first impressions, build process, and testing, and who knows — maybe even participation at an upcoming event like SMRRF! 🤞 DeathRacers, Pilots and Spectators at SMRRF2023 Stay tuned for: 📦 Kit unboxing 🛠️ Assembly experience 🎮 Test runs & tuning 🏁 Event-ready (or not 😅) Feel free to drop your own tips, questions, or DeathRacer setups below 👇
  21. That’s a lot of engineering-grade filament to test. With the Creality K2 Plus, Snapmaker Artisan, and SUNLU E2, I think I’m well equipped. 👨‍🏭 It’s Engineering-grade filament: PA6-CF, PA12-CF, PC-ABS (white), Nylon PA6/66. I also have their popular materials such as TPU (black), PLA (matte Black), PETG (white), and ASA (black). If you'd like me to test anything specific, please let me know here in this thread. Check the availability of their filament on their official website.
  22. 🐣 Got Easter-themed 3D prints? Share your decorations, gifts, or functional models — whether you designed it, printed it, or just have a cool remix! Featured: Bugman140, 3DPrintBunny, KOZA-Designs, 3DWithUs 📸 Post your photos, tell us what filament you used, and drop a link to the model (if it's public). ✅ STL sources (Printables, MyMiniFactory, Cults, etc.) welcome ✅ Designed by you or others — just credit the designer ✅ Cross-technology prints/projects are welcome ❌ No AI renders or unprinted designs 🐰 Let’s keep this growing — we’ll feature some of your entries in our Easter 3D Print Ideas post and social media roundups.
  23. We love seeing what our members are building! You’re welcome to share personal projects, blogs, or shops — but please keep it relevant and add context. ✅ Links to your own 3D prints, designs, or tutorials are encouraged when accompanied by insight, context, or helpful tips. ✅ Showcasing your tools, setups, or maker projects? Please do! 💡 If you’re sharing a video, provide a brief summary so others know what to expect. 🚫 Please avoid posting just a link without context — it’s more helpful when we know what it’s about and why it matters. 🚫 No spam, AI-generated posts, or “visit my forum/site” link drops. 🚫 Affiliate links are not allowed.
  24. Always wanted to try #3Dscanning with a large turntable. Revopoint offers one - with a max load of up to 200 kg. Phew… 😅 I don’t have to lose weight.
  25. Richard Hirst posted a post in a topic in SMRRF
  26. Max Funkner posted a post in a topic in SMRRF
  27. Max Funkner posted a post in a topic in SMRRF
    We have been visiting SMRRF for a few years now, and have kept a single evolving article updated with highlights from each show. From exciting product launches to standout displays, it's been a go-to for yearly 3D printing event coverage. 🔗 Full article with links, photos, and past coverage: 👉 SMRRF Yearly Highlights DeathRacers, Pilots and Spectators at SMRRF2023 💬 Have your own SMRRF experience to share? Whether you’re attending this year, exhibiting, or just following online, we’d love to hear from you! 👉 Comment here or start a new thread in the SMRRF Forum to share your insights, photos, or impressions.
  28. Max Funkner posted a post in a topic in Formnext
    We’re covering Formnext again this year! Do you have ideas or special requests on what to visit? Leave a comment here! 👇 Whether it’s a booth you’re curious about, a product launch you want covered, or just something fun happening at the show — I’ll do my best to check it out and share!
  29. Max Funkner posted a post in a topic in Formnext
    I’ve been visiting Formnext for many years now, and have kept a single evolving article updated with highlights from each trade show. From exciting product launches to standout displays, it's been a go-to for yearly 3D printing event coverage. 🔗 Full article with links, photos, and past coverage: 👉 Formnext – 3D Printing Event – Yearly Highlights 💬 Have your own Formnext experience to share? Whether you’re attending this year, exhibiting, or just following online, we’d love to hear from you! 👉 Comment here or start a new thread in the Formnext Forum to share your insights, photos, or impressions.
SUNLU FilaDryer SP2 Launch
