  1. Tap the 3-dot menu (โ‹ฎ) in the top-right corner of the browser.
Posted
Just gave my first go at vacuum-sealing a filament spool using the EIBOS pump and reusable bags. First impressions? Surprisingly quick and oddly satisfying.
A full guide and video covering how these pumps work, and long-term storage tips, will be coming soon to 3DWithUs.
UPDATE: Full guide is live.
Filament Vacuum Pumps & Reusable Bags: Complete Guide
โœ https://3dwithus.com/filament-vacuum-pumps-reusable-storage-bags
๐Ÿ’ฌ Have you tried vacuum storage yet?
If youโ€™ve tried vacuum-sealing your filament, share your results (and fails!) below.
Great attempt! Iโ€™ve been wondering whether itโ€™s really necessary to get a filament dryer โ€” have you ever used one?
Iโ€™ve tested a few filament dryers and always keep them handy. I would still recommend having a filament dryer available โ€” especially if you live in humid regions like the UK, for example. Moisture is everywhere.
Letโ€™s say you open a spool and leave it printing overnight. When you seal it back using a vacuum pump and desiccant dehumidifiers, that may not be enough to restore the humidity to ideal levels. In such cases, I recommend drying the filament before sealing it โ€” when needed.
It also depends on the filament type. For some engineering-grade materials like PA12-CF, manufacturers even recommend using a filament dryer for a few hours before printing, including with brand-new spools.
Hereโ€™s my test with Inlogic PA12-CF and PA6-CF. Brand-new filament is dried in the SUNLU E2, then fed into the Creality K2 Plus via a PTFE tube. Maybe overkill โ€” but I got beautiful, functional prints!
Thanks for the reply! Iโ€™ve decided to go ahead and get one in the end. Even though itโ€™s just for home use, itโ€™s still pretty frustrating to spend several hours printing something only for it to fail.
Snapmaker U1 Early Bird Offer Banner
QIDI Promotion Campaign
  2. Tap Permissions โ†’ Notifications.
