Creality Hi Combo Print Examples, Settings, Tips
xTool M1 Ultra Discussion
I thoroughly tested the new xTool M1 Ultra, exploring its laser, inkjet, blade, and pen modules, along with optional add-ons such as the heat press and air purifier. My hands-on article includes setup notes, first impressions, and plenty of close-up project photos. 📝 Full article: 👉 https://3dwithus.com/prusa-xl-5-toolheads-review-assembly-prints-examples Have you tried the M1 Ultra or any other xTool system? 💬 Share your projects, workflows, and tips below — we’d love to see what you’re making
Budget CNC Machines – Discussion
We’ve just published our new guide: Best Budget CNC Machines. In the article, we cover popular entry-level CNC routers, including the Lunyee 3018 Pro Ultra, TwoTrees TTC450 Pro, and Snapmaker with the 4-axis module. We also touch on important points like noise, dust extraction, materials, and the learning curve with software. This thread is for the community side of things. Have you tried any of these machines, or do you use a different budget or even DIY CNC in your workshop? Share your projec
Prusa3D XL 5 Tool Heads & Enclosure is Here
Thanks to @SamPrentice, I’ve got the special opportunity to unbox, assemble, and test the Prusa XL with all five tool heads and its enclosure! Full coverage coming to the 3DPUK TECH YouTube channel, along with a written article for 3DWithUs. Stay tuned!
Sloffies - Parametric slides
"Sloffies" is an Afrikaans nickname for slides and flip-flops. I have designed Sloffies to be parametric so anyone can customize them for their feet using the customizer on MakerWorld. You can also download the script on GitHub and use the OpenSCAD customizer to customize them; the UI is just not as intuitive as the customizer on MakerWorld. Where it started I designed the slides and accompanying packaging as part of a shoe design competition. The competition, unfortunately, didn't work out f
Revopoint INPIRE 2 is Here
New Arrival: Revopoint INSPIRE 2 Just received the INSPIRE 2 for testing (Teddy helped with the delivery 🐶). I’ll be sharing first impressions and test scans soon. What do we have: Quick Look: The INSPIRE 2 is Revopoint’s lightweight, go-anywhere 3D scanner, built for creators, designers, and educators. Weighing just 450g, it offers up to 0.03 mm precision and volumetric accuracy of 0.05mm + 0.1mm × L (m). This scanner is built on Revopoint INPIRE, Andrew Sink tested in the past: https://3dwit
Create an account or sign in to comment
