A browser-based way to inspect STEP and STL files before a project moves on
Hi everyone — we’re the team behind CADProps. We built it for those moments when someone sends you a CAD file and you want to inspect the model and check its dimensions without installing another desktop application.
For example, you can open a STEP file, rotate the model, check its units and overall dimensions, and inspect geometry properties. CADProps also opens STL and other supported mesh formats, which can be useful when checking a model received for a 3D printing project.
If you’d like to try it with a known sample, we’ve put public STEP and STL files here: https://www.cadprops.com
We’d be interested to hear what you usually check first when receiving someone else’s model. Are dimensions, units, geometry properties, or comparing versions the most useful to you?
— CADProps
Edited by CADProps
