Balance Tetris game - Customizable
Hi! I would like to showcase another project of mine: A Balance Tetris Game!
How to play?
Take turns by placing blocks on the base by either rolling the die for it or choosing a preferred block. If the tower collapses on your turn, you lose!
Printing tips:
  • Different wall count and infill % have great impact on the game. I used 2 walls and 15% for every piece. You can print the base with 0 infill, 0 top/bottom layers.
  • Scale it to your preferred size! 50% works just fine as well! I also recommend scaling the tetris die up to 133% (20mm).
  • I recommend printing the solid blocks and the base on a holographic plate. It gives them a great look (Check out the last few pictures)!
How to customize your own:
To use the project files (.FCStd) you will need FreeCAD, a free to use/download CAD software. After opening the project you will see on the left side all the folders with the models and parameters. When you are done just export the models one by one: Select one of the models, then press Ctrl + e or Top menu > File > Export...
The parameters:
  • BaseArcOffset: Offsets the (circle's) arc on the base piece.
  • BaseTeethCount: The number of teeth (slots) on the base piece.
  • EdgeLength: The size of the blocks.
  • GridWallWidth: The wall width of the Grid Blocks. (Solid blocks are not affected)
  • DiceEmbossDepth: The depth of the emboss on the dice
  • PedestalLength: The horizontal length of the pedestal. (The width is always 3 * EdgeLength)
  • PedestalSlotDepth: The depth of the slot the base goes into.
  • PedestalHeight: The height of the pedestal.
The project is not foolproof, setting negative/incorrect parameter values might mess up the geometry completely!
Happy printing and customizing!
I hope you like it! The project is available here:
https://www.printables.com/model/1549635-balance-tetris-customizable
Other pictures:
Great project! Good luck in the Balancing Games contest.
I printed the dice so far. It came out nicely. It’s a shame it takes so many color changes for the multicolor version (four colors). It took me 120 color changes and over seven hours to print, with a lot of purging. Hopefully, the next generation of tool- or nozzle-changing printers will make printing multicolored dice more feasible.
I can imagine that in this game, if you print many more objects, there could be two dice — one for the shape and another for the color code.
Thanks!
The die wasn't meant to be printed in multicolor :D, I printed it out in 1 color and then colored the shapes in with a sharpie. But yours came out great!
Create an account or sign in to comment
3DMakerpro Raven LiDAR Spatial 3D Scanner
